Threedoor
- 10
- 3
- Lewiston, ID
I have an 83 M10a with the Prestolite alternator on it which o believe to be the same as the 900 series trucks.
I had a battery with two bad cells in it and lost the voltage regulator. It was overcharging. Chared parts in the regulator.
I replaced the batteries, fixed some connectivity issues. Checked ground to the alternator and it’s good. Brushes look great, no abnormal wear on the slip rings. Rectifier looks good. I Have 25V back to the field and nothing. Adjusting the pot does not bring the voltage up.
What I think I did was screwed up the position of the three wires between the rectifier and voltage regulator. I have TM 9-2920-225-34 and it does not help. As there is no diagram of the correct position for those three wires.
I took a picture of it on disassembly but think I still managed to get it wrong.
