Price check - axle seal kit
FMJ
36
Las Cruces, NM
I don't know, prince's can be expensive. . . :razz:
Sounds like a decent prince to me though. considering what memphis and others get for the parts individually
m16ty
210
Dickson,TN
I can get the inner and outer seals for $9.50 each. I use RTV for the axle flange and the keyway.
DieselBob
13
Arnold Maryland
If you are talking seals only and not the gaskets and cork wedges that would be a little pricey. As for seals you need 6 inner seals and 4 outer seals. they run from $8 to $20 each from what I see.
212sparky
Monroe/ Ohio
I have to redo the seals in my front end and starting to shop around for the best price. I am thinking seals, boots, maby bearings, bushings. If i am going through every thing i may as well rebuild with new parts so i know it is in good condition so i wont have to tear in to it for a long time.
paulfarber
19
Gordon, PA
jasonjc
283
Gravette Ar.
Some on here have bought up a good point about using the outer seals on the front also. If water/junk gets into a bad boot it can and will get to the brearings unless you use the outer seal.
paulfarber
19
Gordon, PA
I got the seals yesterday and all were NOS still in GI packaging.
Not a bad deal... $50 for all the seals for a rear axle.
I could have lived without the little religious-freak booklet telling me I'm going to ****... but at least the parts were in good shape.
Mike929
22
DFW, Tx
I saw a set of bearings (2) and races(2) priced at $120 at eastern supply. Seemed a bit high to me, but I am new to the market.
