- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Cost, best place to buy etc (LDT465-1).
I have standard Mains in stock if anybody needs them. (Memphis buys them for me!!)cranetruck said:Cost, best place to buy etc (LDT465-1).
Only trouble here is you've got to inspect and the mike crank journals first. If the crank shows any wear (grooves etc.) then you have to get the journals ground and fit undersized bearings (yea, it sounds backwards, the bearings are actually oversized because the journal is actually undersized after it is ground, but industry practice is to call the bearings undersized). Even if the journal is smooth you still might need undersized bearings, so don't order them until the engine is torn down and you KNOW if you need standard or undersized bearings!WillWagner said:I called Clevite. they need a number off of the brg. They said they might be able to match it by NSN, but i can't download things at work. Anyone got the NSN for the rods and mains? Havn't tried Federal Mogul yet.
I agree --- I would never install new bngs without first verifying. As tempting as it is, given the uncertainty of not knowing if something has been previously turned I'm going to wait till I can verify what I need before ordering.I would never trust depot tags or assume a bearing size... you really HAVE TO PULL the bearings and see what you have in the engine, assuming will land you in a parts mess!!
That's good to know --- thanksYes there is a mic that you can measure the main journals with the crank installed in the engine.
