Pulling an M105 trailer behind a M1009?
190
Albuquerque NM
Hey all,
Can anyone comment on the possibility of pulling an M105 trailer behind a M1009 while unloaded? It seems I may have a trailer on the way, but I don't have an easy way to tow it at the moment except by hooking up to my M1009.
Wouldn't be going too far, some highway miles though. Good idea or bad idea? Also is the trailer wiring connector the same or will I have to come up with an adapter/hack into the wiring harness?
emmado22
147
Mid Hudson Valley NY
For a one time thing empty, yeah, you'll probably be OK... Go slow though..... Trailer plug will hook right in. You WONT have any brakes on the trailer though..
1,807
Agreed with Mark. Your lights will be dim as well since the trailer will have 24V bulbs and the CUCV 12V
emmado22
147
Also, you'll need either 3-4 friends to help you get it hooked/unhooked, or a jack of some sort.. One guy CAN NOT hook it up byhimself due to the difference in heights... Trust me...
rottiedog
New Bern, NC
I towed one home but had to lower the tailgate because it was creating a ton of draq. I have lowered my m105 to a more usable level with a 4" drop trailer axle.
We just pulled a 1.5 T generator trailer with two 5 K gensets and accessories mounted on it about 90 miles from Mechanicsburg with my M1009. The trailer lunette was turned down, which made the load ride nearly level. The trailer lights worked fine, if just a little dim on the 12V system. As long as you maintain adequate braking distance to anything in front of you and plan ahead for all stops and turns you will be OK. You must be constantly aware of the significantly increased braking distance and the fact that you cannot accelerate quickly. I would not reccomend this as a routine activity, it is alright to recover a new acquisition but not for reqular use. Drive safely.
