Push button headlight switch testing.
Jones
Sacramento, California
I've got two push button headlight switches and want to test them but have nothing with 24 volt M-series wiring system I can plug them into. Is there any way to test these (VOM?) to make sure I don't just have 2 push button headlight switch paperweights?
Jones
Good idea with a 24v source.
I know the switches are static sensitive; even to the point of being told to connect the ground to the switch body first before plugging it into the wiring harness. Just as soon not smoke it while testing it to see if it's good.
williamh
629
SanDiego Ca.
Just curious , how do you have a couple of 24v push button switches but no truck to put them in to test ? I have always wanted a couple just never could find one I wanted to spend that kind of money on. Having said that🥲 I have several old style switch’s and when I tested them I just hooked them into the trucks harness and tried them out. Had someone stand behind the truck to check the break lights tho. 😜
Jones
It's a gift-- and a curse. After having a few deuces and starting my baby HEMTT project, I seem to have managed to end up with some spare parts that I'm still unearthing.
Trades / swaps / being paid in parts for some fabrication projects for others-- it all seems to accumulate... or maybe it just multiplies in the dark?
After my back surgery and a lifetime 10# lifting restriction (regularly ignored), I resigned myself to only taking on projects where any given part or sub-assembly weighs less than I do.
Current inventory / debris field includes but is not limited to; two MaxAx kits minus the pouches, a few extra attachments for same, an EMCU-116 power supply w/ cables, one LED parking light, one LED tail light, gutted housings for same, one three-lever light switch, two push button light switches, two armored vehicle headlight assys w/ the vehicle mount sockets the lights attach to, a large binder-sized "Transportability Guide" which tells weights and dimensions and how to secure almost all M-Series equipment, two not-sure-what-they-fit interior lights, two NOS curved outrigger instruction plates for a HEMTT, five crimp-on cable terminals (the hard to find ones with the tab that comes out the center; used inside the NATO plug slave cable head)., bits and pieces of M-37 era slave cable connectors. a NIB SINGARS radio rack / mounting assy., some stuff even I can't identify... and I'm still stumbling across stuff.
