putting my woman to work...
srodocker
68
Lacey, Washington
Welp gf's dad took down there deck since it was all rotten and falling apart. I told him when i got the truck shes ready to work at any time you need her. well we set it up for a dump run yesterday. 2100lbs of wood and other junk and 117$ later she did a good job. you should have seen the looks on peoples faces at the dump hhahah. but having a dump bed would have been a lot easier maybe a future project down the road...
she also go her first bath in who knows how long and i also painted the wheels black instead of all sorts of different shades of green. used some engine degreaser and holy cow my engine is SO clean now!!!
1stDeuce
15
Farmington, NM
Cool! I have used mine to haul two roofs worth of shingles to the dump now. Not hauling any more until it gets a dump bed conversion!! :)
I wonder what was mounted on the driver's side of your bed... Looks like pipe inserts welded into the lower bed side. Never seen that before.
C
Jakob
Louisville, KY
I recently took over a ton of scrap metal to the recycling yard. That wasn't fun unloading by hand either, but it was the easiest $200+ I've made in a while!
srodocker
68
Lacey, Washington
oh it did zout!!! thanks a ton! im trying to find a green vinyl paint tho...so i can match for when i paint my truck
when doing a dump do you need to remove the rear pintal? or anything like that?
LanceRobson
206
Pinnacle, Stokes County, NC
An easy way to unload shingles and other construction debris is to put some old pallets in the bed before you load. Thread a chain from the tailgate to the front and put the excess on the cab roof while loading. When you get to the dump have the guy with the front end loader or compacter pull the stuff out. It's get about 90% of it out in less than a minute. You can usually save the pallets.
This won't work at the places where you have to unload into a compactor or dumpster but for those of us who go directly to the landfill, it works well.
Lance
Jakob
Louisville, KY
Lance
That's a good idea. I'd had that same kind of thought, but couldn't figure out what to use underneath of everything.
