- 3,212
- 380
- 83
- Tonopah, AZ
I am about to remove my transmission on my M35A2 and I have some questions for you guys.
I looked at the TM and it tells you to remove them, but can you just do it with out removing them all the way?
1. Do you have to remove the PTO to get the clearance you need to move the transmission back?
2. Do you have to remove the jack shaft all the way out or can you just move it to one side?
The problem I am having is I am getting oil out of the bell housing hole, I think it is gear oil form the transmission and the clutch has started to slip.
