Rebuilt 250 has maxed out oil pressure
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Just completed rebuild, in frame kit of the 818. Now it maxes out the pressure on the gauge. Any thoughts on this? Thanks
Manual gauge or electric? Verify with a mechanical gauge. Electric could be all over
Or use a meter and see how many ohms the sender unit has while it is running generally 1ohm per psi
WillWagner
2,607
Monrovia, Ca.
Put a known good gauge in one of the ports. Verify against the dash gauge. No troubleshooting for high OP per Cummins, but, a stuck regulator will cause it. Did your failure put debris into the oil pan? If so, godd possibility debris in the regulator.
5_TON_TOMATOE
OLYMPIA/WA
Had the high pressure BEFORE the 50 yr old valve broke:cry:
