- 6,610
- 9,211
- 113
- Papalote, TX
When I rebuilt my fuel tank I decided to go with the fuel sending unit that did not have the float arm, I thought it would be handy with all the mods I had to make for the Duramax install not to have to worry about the float arm, as it turns out that sending unit is what is called a reed switch sending unit, just be aware if you use it appears you will only have 5 "steps" ever registering on the gauge, these are approximately Empty, 1/4, 1/2, 3/4 and full and for the most part is about 1/4 tank behind, empty can be anything up to 5 gal and it almost immediately comes of of full to about 3/4 just a few miles after you fill up.
