Replacing 5ton fan belts??
dm22630
42
Front Royal, VA 22630
BOTH of the fan belts on my M818 broke on my way home. Now, it will overheat if it sits still & since the fan also turns the generator belts, the batts die.
I bought replacement belts, but cant figure out how to put them on.
I have searched & searched w/no luck.
Any tips?
Thanks!
oilcan
Ohio
Loosen up the water pump bolts and turn it until there's enough slack to get the belts on.
Don't forget to tighten up the bolts after the belt tension is set!
ncduece
wilmington nc
there are three bolts were the fan mount bolts to the block if you look carefully you can see that the holes are slotted. just loosen them up. then look between the alt and the fan mount there is and adjustment screw has 3/4 head and 7/8 stop. you will need a deep well 7/8s. basically the hole fan slides to tighten the belts. the water pump has 6 bolts in a circle loosen them and turn the whole pump to tighten the pump belt .the pump is made eccentric
grounded
Banned
928
defiance oh
cranetruck i will be back at daniels wed or thursday ;) let me know when your coming ill try to meet up with you if its around when im coming
powerhouseduece
Pasadena, Md
Hey guys. I got a m818 that the belts were missing on. I jumped over to the old site and got the napa part # and come to find out the belts are to short. I have loosened the fan and have it adjusted all the way to the right and I still can't squeeze the belt on. I can't open the TM's cause I'm on my cell phone. Technology has only brought us so far. Anyone have a quick answer besides get longer belts? I had to order them and they will be here at 1530 today.
powerhouseduece
Pasadena, Md
Ok guy we got it all figured out with a few phone calls later. The part #'s in the cross reference guide for the 250's for. A five ton are incorrect. The reference states that napa belt # is 2522401 but the fitting number is 2524407.
I have not had to replace the other belts so I don't know if there the same...
Well I guess I have to wait till monday to try and get it running.
Westech
CPL
6,104
206
cow farts, Wisconsin
HMM... I did that cross my self and installed the belts on my 813.. they were a touch tight but I got them on no problem. I guess a size larger would work with the amount of adjustment in the system.
BEASTMASTER
140
Burgaw, N.C.
i used the cross parts chart for oil filters and ordered four because they were on sale. ha ha wrong filters. i think guys put wrong #'s on there for kicks.
