Replacing lift pump
Rrent
142
Texas
I have a new (Hillbilly Wizard) lift pump in-coming. My truck is at my business 40 miles from my home garage. I’m trying to gather up everything I might need. What size/lengths of gas line should I have on hand? RTV and grease (to hold the shaft out of the way)… any other supplies, I haven’t thought of?48DFD512-A92A-416F-8193-B5D24A493B3E.jpeg
Barrman
1,556
Giddings, Texas
5/8 and 11/16 flare nut wrenches for the solid fuel line.
15mm socket for the solid fuel line holder halfway up the front of the engine
1/4" drive sockets have done me well for the actual mount bolts. Swivel sockets work well too.
A stool or something to stand on for trying to do the stuff on top.
Flattened card board box for the underneath work.
There is a company selling brand new flexible fuel hoses for 1975 vintage Corvettes. Exact same part number as the CUCV fuel hose.
Rrent
142
Texas
Thanks - this is exactly what I was looking for. I’m going to clean it up and track the lines this weekend. Should have the pump by next weekend - all the fun.
19,037
Does the 6.2 need a dab of petrolatum to hold the shaft in place?
That is an amazing "shop trick" to hold that rod in place for sure!
Great part is that it washes away after a few miles of run time too...
cucvrus
9,603
Jonestown Pennsylvania
Make sure you get the cover plate gasket and start every bolt and fitting first before tightening any of them. You can do 99% of the job top side. And as easy as it is to remove Gen it sure beats having dirt and oil in your face. I have encountered a few that the 3/8 pump bolts were seized in the housing and ended up breaking the fuel pump off and replacing the bolts after I man handled them to get them out. Be careful and it should be a fairly easy job. Good Luck.
