Replacing Rear Main Oil Seal On 6.5L non Turbo
WhoMe08721
123
Bayville/NJ
Hey Guys,
My rear main oil seal on my 6.5L non turbo is starting to leak. First off has any one replaced one before and is there a write up on this subject? After doing some research in TM manuals. It looks like you have to disassemble johnny 5 to the core and pull out the crankshaft this seems like a lot of work, Is this true or can you just drop the transmission, pull the flywheel and replace the seal.
Mogman
9,212
Papalote, TX
You do not need to dissemble the engine to replace the rear seal on a 6.5L, have you followed the second paragraph on the first page you posted?
If you have a fording CDR valve are you sure it is in the right position?
It is not unheard of but relatively rare the rear seal would leak on a 6.5L
You can check youtube on replacing any of the 360 rear seals on GM vehicles as they will all be nearly the same.
Retiredwarhorses
4,135
Brentwood, Calif
6.5 requires trans comes out to change seal…I would make sure it’s even your rear main, very rare they leak, 99.9% of the time its your rear pan seal…
6.2 rear main is a 2 piece seal…done differently.
