Reprograming CTIS
Strobi1
Chesapeake
I have a 1996 BAE M1078 with a newer reprograming CTIS ECU. I do not have the standard din 9 plug on the dash since the truck is older. I think I would have to plug straight into the ECU to reprogram tire pressure settings? Has anyone run into the same issues? If so, how have you over come it? Thanks!
Sent from my ZTE A2017U using Tapatalk
pontiac62
battle creek, mi
This is from Sean fillner channel on you tube. This the one he put in for getting higher highway pressure. Believe he mentioned it was an mrap ctis . Not sure if this helps, but one way. Disclaimer I’m not a ctis guru.
Man of few words
M1081 LVAD
