Rod bolt torque
mark salanco
greenville sc
Looking in the TM, I see 2 different rod bolt torque values listed.
LDT 465-1C 81-86 pound feet
LDS-465-A1 81-86 pound feet
LDS-465-2. 95-100 pound feet
The engine I'm rebuilding is an LDT, with the TD block.
I purchased new 12 point rod bolts, so what is the torque value?
SCSG-G4
PSVB 3003
3,190
Lexington, South Carolina
It's the engine that's being rebuilt that requires a different torque spec LDS-465-2 takes more torque as you found out, so if you are building an LDT-465, or an LDS-465-1A, you use the lower value.
mark salanco
greenville sc
So the LDS-465-2 has different connecting rods in?
Just trying to sort this out, I was under the impression that rod bolt torque was determined by the rod bolt characteristics, to achieve the proper bolt stretch.
I remembering building Chevy engines, the ARP rod bolts had a different torque requirement than the stock Chevy rod bolt.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
The lds-2 has 210hp and only came in the m656 tractor/cargo. It has subtle differences, but is also quite rare. Unlesss you got lds-2 rods, use 85ft lbs.
