Sent PM not showing up in the Sent mail box.
islandguydon
782
Michigan
I have sent a few PM's and when I go to the sent mail drop down it does not show as even being sent. What would cause this to happen. I sent recovery4x4 2 separate pm's and as far as I can tell they disapeared...?
tie6044
42
Blaine, MN
I know this is as obvious a question as asking someone if the switch is on when starting something but is your PM box full?
islandguydon
782
Michigan
Nope, I cleared it out a week ago. Just seems fishy I can PM others and it shows up but not Kenny..? I just pm'd him again with the same result. What am I missing here..?
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Go to your user control panel, and click "Edit Options" on the left side.
Once that screen opens you will see a section for "Messaging and Notification". At the bottom of that section, make sure the box is checked for "Save a copy of sent messages in my sent items folder by default"
I am pretty sure yours is not checked. I looked at your profile through my moderator screen and it is not selected, but I cannot change it for you...only yourself or an admin can do it, I can only view it.
islandguydon
782
Michigan
Phil, The box is checked by default.
Speeddmon, I did what you suggested, the box was not checked so I checked it and saved.
My question is, If the system saved everyone else's Pm's why does it elect not to save just 1 members mail being sent..?
1,814
I run my account under the guise of anonymity. If you sent anythiing to me, you sent it into the black abyss.
