side window parts and a question
Bill in pa
40
homer city pa
I need two sets of the thin metal that holds the
passenger and driver side roll up window rubber in place.
I have new rubber molding but since I built the quad cab I need another set of the metal that's used to mount the rubber.
There are a few different model trucks and probable more I don't know of.
Should be on the, M35, 800 series M39 M939.
Some one has to have some some where.
What did you Quad cab builders use for trim on the side windows.
Bill in pa
40
homer city pa
Not it.
I need the thin metal that holds the rubber trim that the window closes against.
The metal and trim actually attach to the under side of the roof.
cattlerepairman
3,264
NORTH (Canada)
Well, you sent me on a quest!
I can tell you where it is NOT:
- it is not part of the hardtop kit: 8 is the roof and has no further distinct parts,
The forward facing part the cab door window frame rests on seems to be part of the windshield assembly (16 and 18):
That leaves the more detailed cab door and glass assembly....:
Any luck with this drawing?
cattlerepairman
3,264
NORTH (Canada)
AH!!!!
11 PAOZZ 2590-00-693-0589 19207 7372716 .BEZEL,AUTOMOTIVE TR................ 1
12 PAOZZ 5330-00-737-2722 19207 7372722 .SEAL,NONMETALLIC SP................ 1
cattlerepairman
3,264
NORTH (Canada)
A quick Google of 2590-00-693-0589 reveals that a vendor that supports this site has the metal trim in stock... ;-)
Best of luck with your project and I can rest peacefully now!
