Some Fuel Filter Questions and comments about my terrible week.
Retiredwarhorses
4,135
Brentwood, Calif
If this is truly a lifter problem, you need to replace it immediately before Diesel fuel gets beyond the diaphragm and thins out the oil and you score your cylinders and bearings or even seize the engine.
That’s impossible, the vent on an m998 before the mods were done would contaminate the closest geared hub and maybe the front diff.
After the mods to the vent system, the excess fuel is sent back to the fuel tank filler neck in an isolated vent line dedicated the fuel pump vent.
  • Like
Reactions: 98G
98G
Former SSG
4,268
Since this thread is now something of a repository of fuel system info, above is the video showing lift pump replacement including the plate.
The two fuel pump bolts are 7/16. The threaded fuel hose nut is 5/8.
I'm an idiot and left the switch on so it's stranded where I left it and I'm working on it in direct sun :(
Lift pump is out. The plate is still in place. Any difficulties and I'll just pull the plate as well.
Hopefully I'll be updating this with further progress later this evening.
marchplumber
2,732
Peoria, Illinois
Don't ya HATE when ya do something, THEN realize you could've done it different/better? UGH! I feel for ya, in plumbing, that can be quite often. Looking forward to the update!!
