- 706
- 975
- 93
- Southern Minnesota
I may try the welding idea. I've definitely tapped in on my hand, then a table.. doesn't move. I'll keep trying. (Looking up the parts, including a new speedo, it's only $130 + shipping.. so I may go that route and skip the headaches if I don't make any further progress today.)Sorry not a clue, the only thing I can think of is using a power supply one side connected to the brass ring and the other connected to a nail with a sharp tip, the idea is you weld the point of the nail to the broken piece, it would take some experimentation on another portion of the cable to get the volts/amps right.
I guess you have tried tapping it on a table with less than destructive force
Edit: Yes it's the mechanical 60 MPH...Is it just a 60MPH gauge? a used one should be relativity cheap, I think I even have a couple floating around here, but new is nice also!!
If it is a new cable I would be looking for where it is kinked, on a used cable pull the entire center cable out of the jacket (top), grease up the entire length with bearing grease and put it back in. NOTE if the jacket was not damaged you could have just replaced the inner cableGot the speedometer and cable replaced.. Was a messy job, but not overly difficult. Start at the dash and work back to the transfer case, reverse the order for install.
One thing, my new speedometer/cable is causing the needle to bounce a LOT. Is there some sort of lube I should drop into the dash side of the cable to hopefully let it spin more freely?
This is the original style, the cable goes out the side of the firewall by the fuel filter. But I will double check this tomorrow. Just frustrated why it worked once, and now a dozen more tries same failure mode.Make sure it is sliding in and out the firewall when you pull/push on the cable and not getting a bend in it when you put the panel back in, or maybe pull on the cable from near the master cylinder and see if you can pull a little bit out. (easy on it!)
