Spindle nut
Usmc83
California
Just recently checked spindle nut on my 85 998 1038 . It has the old 4 slot spindle nut. Tab is secure and holds just fine. My question is should I upgrade to 8 slot nut ? If so can I just replace the nut itself or do I need to replace washers and spindle nut washers as well ?
Mogman
9,211
Papalote, TX
I would, there is a reason there is an "upgrade" for that part, I always replace the "washer, key" any time the nut is removed, just too cheap not to.
I just looked and AMG has both the nuts and the tabs listed, under $20 for the pair plus shipping of course, fleabay even cheaper
Usmc83
California
Thank you
frank8003
4,984
Ft. Lauderdale, Florida
many upgrades are for safety
HECK WHAT DO I know .....................
I would compare.
All the engineering specifications between, one to the other
The world is at your feet
considering .....................the differences
You already got it made
but hen.. I are ikd..
Ajax MD
1,414
Mayo, MD
My thought on this is- If you're going to upgrade, upgrade to the absolute safest option. None of the AMG stuff is very good or reusable. Buy this kit from Mod Mafia or one of the other vendors or don't touch it at all.
Yes, it's stupidly expensive but it's the most secure locking method and it's totally reusable. You'll never buy it again unless you booger it up during removal or installation.
Mogman
9,211
Papalote, TX
You are right that is stupidly expensive,
Action
1,556
East Tennessee
Isn't the issue from improper installation? Or reuse of old parts. Has anything fell apart that was assembled at the factory?
Ajax MD
1,414
Mayo, MD
My understanding is- "Yes."
The Army had a massive program of rechecking every HMMWV and marking them on the body that they were "checked." This was after factory assembly.
The first tabbed washers only engaged a single finger. The second style engages 2 fingers. The 3rd style is still not reusable.
I really try not to buy too much into aftermarket hype but this is one case where I feel the aftermarket product is markedly superior. You won't catch me putting those "heat sink" portal hub covers on my truck, for example.
86humv
498
Texas
Those bluehummer kits were once $ 79....What happened ?
