Spitter valve
BenRoberts
Certified insane
1,367
208
southwest/ohio
curious if the spitter valve on the bottom of the air dryer can be purchased separately from the air dryer. The one on my truck gets stuck from time to time.
juanprado
2,707
Metairie/La (N'awlins)
Many threads on this. Recommend change complete unit with new style.
Yes you can rebuild and different levels of rebuild kit available. Valve is available and needs new oring and bore honed or sanded. Will also need new filter and colescesent filter.
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
124
Sandwich, MA
Hey Ben, Suprman here on SS sells the new model for a great price. Great guy to do business with. Have one on my truck, works great.
BenRoberts
Certified insane
1,367
208
southwest/ohio
The issue on the truck is fairly cut and dry for me. Each time it purges the air it gets stuck and I will pull over and push the valve up with a screw driver and i would be good till it spits again. I got it working again with some pb blaster but I will be ordering a new one from suprman since I dont trust it anymore.
