starter relay question
dconn22
Dallas, TX
I still have the GM starter relay installed [under dash]. I have read about the "Doghead Mod" and was wondering if the same [upgraded NAPA] relay used for the glow plugs could be used for the under dash starter relay instead of the one Doghead uses???
Curtisje
666
Okinawa, Japan
I think you could. It is probably overkill with that large of a relay. Yiu could also just bypass the relay by wiring in a simple push button for the starter. I've done that before. Or just order a replacement relay for about $35.
83k30
Jax, Fl
You will have to change wiring terminals but just about any good relay is better than the factory "sticky" relay. The "doghead" relay can be found at any parts store and is fairly cheap.
dconn22
Dallas, TX
I figured the size was "overkill" but I have an extra new one and the cost difference is negligible and I plan to use that relay in my camper in a couple places so I will have better interchangeability.
Curtisje
666
Okinawa, Japan
Well if you already have it then wire it in and go. How about sharing a picture of the rig?
dconn22
Dallas, TX
I'll get a few this week and post them. I have so many things to do on it. It is so new to me I got it stuck in the back yard and was struggling to get to to move when suddenly I realized I bought a 4X4 ha ha ha LOL!!! 4X4 works...
