Steering adjustment
Pb101
32
13
Mass
Hey all, I have a 1964 m54a2. The steering on my truck has about 1/4 to 1/2 a turn of play before the steering engages. is there any adjustment on the steering box or column that would help reduce this play? possible linkages that could just be worn out and need to be replaced?
Thank you in advanced for the help!
Paul
G744
3,455
Hidden Valley, Az
Your truck went thru rebuild at some time in it's life. That is how it inherited the power steering system from the 800-series trucks. It was a good modification, with better performance overall.
There is an adjustment on the steering box, check with the TM's for that . Otherwise, go thru all the moving joints in the steering system, looking for slop. Tie rod ends, king pin bearings, drag link, eTc.
Also check the toe, it differs with taller tires. Inflation, too.
DG
Pb101
32
13
Mass
DG
Thank you.
Pb101
32
13
Mass
Do they make a rebuild kit for these steering boxes? Just started to leak out of the front seal. Might as well rebuild it if I have to replace the seals. Thanks.
INFChief
1,343
New York
DG
The drag link is often overlooked!
