stock vs variable rate springs
erasedhammer
59
Maryland
Saw on ebay a listing for variable rate springs for a humvee. Anyone know how this affects ride quality?
or
Do humvees come with these variable rate springs, and would stock linear springs ride smoother?
Carrera911
31
Cumming, Georgia
I noticed one of my trucks has the smaller front springs in the back as well. It does ride noticeably smoother than my other truck with the heavier rear springs.
erasedhammer
59
Maryland
Just keep in mind that to use them you need the cast upper spring perches and later style lower control arms.
As far as I understand the variable rate springs are softer than the heavy duty springs when unloaded but can withstand heavy loads. H1s had them in the back. So why would I need different control arms if I'm not loading up the rear beyond m998 gvws?
DatGuyC
22
Essex, Maryland
Because the spring pockets are different in the later versions to accept the progressive springs, they wont sit properly in the earlier style.
Mogman
9,211
Papalote, TX
Does anyone have the part numbers or application of the "later" model lower control arms. are they the same as the lower front arms of the later vehicles?
I think they are 2530014208634 and 2530014207895 and it looks like they are used in the front also, wonder where I can get a pair of these?
86humv
498
Texas
8634 is RF or LR
7895 is LF or RR
These are the A2 A arms.
They have serrated edge bushings.
Late style have smooth bushings.
