Stripped a spindle/brake frame double ended thread stud
Micmada
211
Florida
Anyone know what type/size stud are used that hold the brake assembly to the axle? I stripped the stud when I apparently over torqued the nut on it. It is a double ended stud like this https://www.summitracing.com/parts/...MIg7WU-9bo8QIVBr_ICh0ifAk_EAkYBiABEgLOp_D_BwE I could not find the torques in the books either. I used 140 ft-lbs, had seen other use 130 ft-lbs. I ended up going 105 ft-lbs on the rest of them. Since I could not back the nut out, I reinserted the stud with it and torqued it also.
19,032
I found a book that has more generic torque specs for bolts by size and thread type. Since you just recently went through the pain, maybe you can look at the attached PDF and see what torque specifications your brake assembly (bolt) might have been? I have rummaged TMs for all kinds of torque specs and found nothing in a lot of cases. This has been my backup plan - rather than not having a number to use.
I am definitely not the all knowing Thor of The Torque Wrench! Just a reasonable place to look...
Micmada
211
Florida
Meritor/axletech # SN-921-1
OK, cool. I think I found some from a distributor but they quote me about $100 per stud.
It looks like they are the same as the PTO stud kit sold at big Mike"s . I will try those first.... Crossing fingers
