- 584
- 583
- 93
- Evansville, IN
Just rebuilt entire front end.. New A arm bushings, ball joints, pitman, idler, sway bar bushings... So, how the Hell do you get this sway bar back on??? The STRUGGLE is real ... Any suggestions would be appreciated.. All hooked up except one end to lower a arm... Cant get bolt to line up..
Ocho Out !!!
Mission accomplished.. loosened it all up, detached sway bar mounts from frame. This allowed me enough play to attach links to lower arms.. Then a ratchet strap from front bumper to sway bar.. Couple of clicks (just a bit of tension) and it went back onto frame bolts...
Ocho Out !!!
