- 9,580
- 218
- 63
- Dickson,TN
I've had my t-case PTO on my truck for awhile now (running a hyd pump for my dump). When I pulled the PTO off the donor truck I couldn't remove the bottom elbow for the lube line because it hit the e-brake bracket. I just installed a standard street "L" black iron elbow when I put the PTO on my truck and forgot about it.
Since then I acquired another truck with a t-case PTO and sold the PTO. In a attempt to let all the parts go with the sold PTO, I pulled the elbow on that PTO to send with it (oddly enough somebody had done some filing on the edge of the elbow so it would clear the e-brake bracket on this one). When I got the elbow off I realized it was more than just a elbow. It's also a check valve.
I looked in the TM (TM9-2520-246-34) and all it shows is just a standard elbow and makes no mention of a check valve in that location. The two t-case PTOs I've dealt with have check valves there.
So the question is, is a check valve required in the bottom elbow (where it screws into the t-case)? I've still got the donor case that my PTO came off of and the elbow with check valve is still on it. Will the pump work ok without the check valve? As I said above, the TM makes no mention of a check valve there. I just don't want to burn up my PTO.
