steelandcanvas
- 85
- 48
- Southwestern Idaho
Need torque and clearance specs for my Deuce. Just exploded a sleeve, it took out a piston, and bugered up the head pretty good. Tried to download a TM, but keep getting Adobe Acrobat errors. Will buy a TM soon, no problem with that, but I need info ASAP. Truck is in mechanic's garage and he needs info to rebuild. I would assume I need:
Head bolt torque
Rod cap torque
Piston ring end gap
Piston to sleeve clearance
Pan bolt torque
And any other measurements he may need.
Thank You to anyone that helps in advance!
Head bolt torque
Rod cap torque
Piston ring end gap
Pan bolt torque
