torque specs
84cucv1ton
New Jersey
just checking.. intake goes to 40lbs and the inection pump gear bolts are 25lbs? i have the tms for some reason the reader is not working.. keeps freezing my computer.. no idea why anyway thanks
84cucv1ton
New Jersey
just getting back to this.. still cant see the tms... the guide pin on the slotted hole on the drive gear?? trying to get this done before i go on go to Florida for a week
brianp454
11
Portland, OR
If you want an alternative to Adobe (that uses much less system resources and doesn't want to update every week) to read, try Foxit or other alternative. If you do a web search you'll find a lot of info on it. Also, Foxit and Bluebeam, etc. allow you to save to pdf much the same as you would print. Very handy for archiving info you wan to save.
