Towing a 5TON 6X6
GILBERT2020
58
MARSHFIELD, MO
Hey men, selling my M62 wrecker and have a lot of guys asking if they could tow it with another wrecker. My question is, do you have to remove the drive lines when towing a 6X6? I remember when I was in the corps, we would just hook to them with a tow bar and pull. Never disconnected anything, just made sure she was in neutral. Thanks for any help.
kendelrio
8,580
Alexandria, La
I may be wrong, but you should be able to put the transmission and t-case in neutral and flat pull it.
G744
3,755
Hidden Valley, Az
At best, have someone in the towed wrecker to help steer.
At least, tie the steering wheel midpoint with a bungee or it will go full lock at the worst possible time after a turn.
Don't forget tacticals are meant to tow other tacticals. Make sure to hook up BOTH air hoses, and open the correct petcocks so the brakes (if servicable) will work on the load.
Dennis
