coachgeo
- 3,405
- 113
- North of Cincy OH
Did lot of searching but seems folk have only done a conversion of existing bed to dump bed.
How about a truck bed dump insert installed in the trailer bed? Clean and easy.. and transferable to other trucks or trailers if sell or ??
Picking up a used insert for an 8' truck bed along with its 12v electric/hydraulic and ram system tomorrow........ So am I going to be the Guinea Pig? or has anyone else done this? Appears the trailer bed is just smidge longer and wider than a truck bed.
how you suggest to wire it? Example ... there will be enough room to put a battery in the trailer..... so should I instead of running a large guage wire to the LMTV battery box to run the electric.... should I put additional battery in trailer.... and run a thinner wire to charge the bed battery? If so how would I do that?
in below video the frame on the ground is what usually gets bolted into the bed of the truck.
https://www.youtube.com/watch?v=74eI6PpqaKw&list=RDQMpiQQnTkmOy8&start_radio=1
