Trailer mod advice
TaylorTradingCo
68
Ringgold, GA
Ok, I know I asked and most of you advised against it, but I bought this trailer. In it's current form, it leaves a lot to be desired, but I think it has the potential to be my new favorite trailer with a few changes.
It has no suspension at all, zero, zip, none. I want to add a set of springs under it, on the cheap. I am leaning towards the axle/suspension off of a 28' pup trailer, but am a little worried it might be just as stiff as solid. Also might consider a set of springs off of a truck, like a F650 or dump truck or something like that.
Suggestions and parts are welcome.
Derek
Jbulach
2,134
Sunman Indiana
Looks scary. Ditch the whole axle and replace it while doing the suspension, or leave bad enough alone and consider it a life lesson...
TaylorTradingCo
68
Ringgold, GA
I do plan to replace the axle with the one that goes with whatever suspension kit I put under it. I like the trailer, just want to make it the way I want it.
TaylorTradingCo
68
Ringgold, GA
Nothing in particular planned, I like it's versatility. Tilt deck for easy drive on, no ramps or fender wells to worry about. Nice 8' wide deck, so can haul two pallets side by side if necessary. Single axle, so easy to turn without side dragging tires.
rchalmers3
30
Irmo, South Carolina
I think that manufactured home companies sometimes remove and stock pile axle assemblies after a home is placed. Sorry, it's not a strong lead, but it may be something worth exploring.
Rick
tobyS
835
IN
Use the rear axle and suspension and frame, tires and wheels from a one ton dually (rear clip). They tow great and you could add a surge brake.
TaylorTradingCo
68
Ringgold, GA
It does have 15" wheels, but the tires are F rated 900-15's. He said they were for a cowboy flatbed and cost $1K. They are super heavy duty and stiff like they were full of concrete.
