transfer case problems
supermechanic
poconos, pa
On a M 51 the t-case wants to jump from high range to neutral when decelerating .
Any known fixes for this?
Does anybody know if this is a common problem?
Tag on side of case indicates depot rebuild some time back.
Somewhat related question, found some cases up for auction,but don't know what model number mine is.
1,120
Do transfer cases have thrust washers?
supermechanic
poconos, pa
A little more info.
I drained and refilled the case , I didn't find any metalic fines in the oil, just oil.
I pulled the access cover near the top rear, thinking that maybe some adjustment was possible to the rail detents.
I couldn't find any adjustment.
Seems to me that the cases are very common items for replacement, due to the large offering at surplus auctions.
So, was this something that the army cured by putting in a rebuilt unit, or is a quick fix available?
73m819
314
gainesville, ga.
the high range sliding gear is worn, i beleave these are syncoed transfers, that to will cause it to pop out of high range, my old m52 did that for 2 years before i replaced the transfer, i found that it was cheaper to put in a god takeout then rebuild it, i just installed a shift gate like what is used on the front winch lever to keep it in high range
supermechanic
poconos, pa
Shift gate sounds like a good idea.
Currenty I use a bungie strap, an idea I borrowed from all of the two stick Macks I ever drove.
Only down side to a gate is that it makes splitting down difficult.
73m819
314
gainesville, ga.
na, i had it set so i just reached down with my wrest against the shift lever and fliped the gate, though most times that i shifted into low range i was stoped. and yes i did the bunge thing until i installed the gate, the gate made it easer for me to shift into low, not having to undo the bunge, i found that split shifting wasnt that effective in the m52 or the 5Ts that i drove in nam, the gearing isnt right for split shifting, not like a twin stick
supermechanic
poconos, pa
Granted, splitting the 5 ton isn't that effective.
But when loaded to the point where I wouldn't want to have D.O.T. scale me, it is more effective than just grinding up a hill in second, with the engine bouncing off the governor, 'cause third gear makes it fall on it's face.
Usually going from Hi, third to Low fifth worked, and then I have the whole box again to row down through.
Getting back into Hi on the roll sometimes proves difficult.
supermechanic
poconos, pa
Hi, All.
Update on the transfer case in my five ton.
I think I puked it.
Not only does it jump out of gear decellerating, but it will not drive in reverse if you keep it in high range.
Drop the transfer into low range, and you can go in reverse, it won't pop out if gear in low range either.
So I now have a dedicated woods buggy untill I can get a new t-case .
Anybody experience something similar?
1,814
Super, check with Jones but i believe a 900 series transfer case is a bolt in and air shift like the deuce. Thinking out loud!
G744
3,451
Hidden Valley, Az
900-series transfer is majorly different in mounting and hookup. It uses a different series drive shaft on 2 of the 3 flanges as well. Overall it is not much larger than that on a duece.
The nice thing is the one on my bench is a three speed with UD, straight, and OD. The bad thing it was pulled for some unknown reason and I have not had time to open it up.
dg
supermechanic
poconos, pa
I believe that the t-case is the same between the m51 and the 800 series.
I think the number is t-138 rockwell.
Someone correct me if I'm wrong.
Also, this may be a good time to upgrade my transmission.
The trans in it currently is the one for the multi-fuel. hence no overdrive.
I'd like to get the OD trans, as I have a top road speed somewhere around 40 mph.
Does anyone know the correct number for the trans?
