Transmission Problem in M925
M35A2-AZ
381
Tonopah, AZ
I took my M925 out for a drive to post office. About 2.5 miles from the house I noticed that the transmission was trying to shift from 3 to 4th then back again, But as it turns out it was just slipping.
I slowed from about 20mph to about 5 mph then stopped. Put it back in gear (5-1) and it did not move, tried rev., did not move. :???:
I started to walk home, got about 50 yds and I heard the trash truck coming, YEA!! he gave me a ride to the house.
Got the M923A1 and the tow bar and headed back to the truck, got the m925 hooked and towed her home, only about 3 miles.
I checked it out this morning and fluid did not look good. So I guess it is transmission repair time.:roll:
M35A2-AZ
381
Tonopah, AZ
I found a transmission and motor combo for sale in CA. Castle Bravo and I went on Tuesday and picked them up, long day but we made it home ok.
Now the work begins, But I am in no rush right now so I can take my time when I/we install it.
M35A2-AZ
381
Tonopah, AZ
Well, after some thinking and a little work, the motor and transmission were ready to pull out.
Castle Bravo, my wife and I pulled the motor out and sat it on the motor stand that I built.
When we pulled it out we had a little problem and put a small hole in the oil pan((*&^%*).aua
The next weekend, I had Castle Bravo and a friend from our MV club came out to help put the new motor and transmission in. We had to get the shoe horn out, but we got it in without anyone getting hurt or anything get damaged.
I got it all hooked up and running this week. YEA!:D
oboyjohn
120
Quebec , Canada
You never know how badly you need a wrecker until you really need one. In the reserves, we have pulled engines with just an A frame set up and chain block. It will get the job done, but you will work a lot harder to do it. But you cannot deny the fact that a wrecker give you just so much more manouverability and control on such a job.
Scar59
41
Mt. Eden, KY
Albert,
Nice work, wreckers do make the difference. I should have spoke up earlier and suggested the dual fuel feed line mod while engine was still out.
rhurey
13
Bothell, WA
Albert,
Is there a way to do that with the engine in? Haven't looked that much yet.
M35A2-AZ
381
Tonopah, AZ
Albert,
Thanks, Castle Bravo told me I need to do it. I guess I should have. Maybe next time.
