Trying to install fast idle.
MLuper7
Eagle River, Alaska
I heard that you can connect a switch somehow to the green wire in front of my intake manifold and that will give me fast idle. Anyone know how to do this? I've searched key words for a couple hours in the forums and I couldn't find anything. I'm still trying to get used to how things work here so I apologize if I'm wasting any ones time.
cliffyp
Brownsville, Texas
Supply the fast idle solenoid with12v and it will engage. Are you trying to put a switch in the cab and leave the stock system in place, or are you just trying to bypass the stock system?
MLuper7
Eagle River, Alaska
M1008 How do I install Fast Idle with a switch in the cab?
I want to put a switch in my cab so I can Turn it up in the winter. It has been converted to 12V from 24V. Any one have any ideas as to how I can make this happen?
panzerwillie
288
miami florida
I done this 2 ways in my M1009 i used a throttle cable and connected to gas pedal and i just pull and lock it , the other was the M1010 i just unlpug the cold start selenoid wire on the IP and put a 12V supply with the a toggle switch and turn it on when i want fast idle just keep in mind you have to used it when first start cold hope this helps
MLuper7
Eagle River, Alaska
Thank you. I prefer to use the cable. Our M1151's are fitted with those and I like them. But finding a cable set up like it would be difficult I think. Thanks again.
panzerwillie
288
miami florida
Any twist and lock cable will work lots of them for sale on internet like the ones used on dueces and 5 tons just need to fab some brackets and connect cable to top of the pedal ... the HMMWV are little hard to use i try thats why i when the other route
1,192
The next time you decide to just start a new thread(duplicate) DON'T, ask a moderator to either move it or delete it.
Cross posting is against the site rules (for several reasons).
I've merged the two threads so as to not waste the members time(that had posted on your thread).
