U-Joint failure
jimmcld
Denton, Texas
I just took a little ride around town to make sure everything was working on my M816. I stopped at a stop sign and when I started to ease off again, I heard a loud metalic snap and some clanging. On top of that, the truck didn't move. Oh s--t! Got out of the truck and looked down on the pavement and found the cap off of one of the u-joints. It was one of the joints connecting the transmission to the transfer case.
Luckily, I had a friend with me and we were just a few blocks away from his M35A3. Let it be known that an M35A3 can tow an M816. However, I wouldn't suggest getting over 20mph. Hooked up the tow bar and drove slowly about 5 miles with me in the M816 with the engine running and the air pressure up, just in case he needed extra brakeing power.
When we got back to my shop, I removed the remaining parts and discovered that none of the bolts holding the u-joint, or the flange plate it attaches to, were more than finger tight. In fact, one of the bolts had backed out of one of the cups on the u-joint completely. That's why the other bolt snapped off. Most of the repairs I have made to this truck were to correct something the army had worked on previously.
Anyway, an easy fix. I just have to wait until Monday because Inland Truck had to order the part.
73m819
314
gainesville, ga.
could be a bearing going out in the xcase, trans, or U joint , or out of time and causing a vibration, this will loosen up the bolts over time, its hard to believe that all the bolts would be loose from the gov, it would have failed A LONG TIME AGO
use locktite on EVERYTHING
jimmcld
Denton, Texas
I think the bolts were loose since the last rebuild ( I believe it only has 1000 miles on it since the last one). This shaft has the Spicer joints in it and all the rest have the Dana joints. Also, the metal tabs that bend over against the bolt heads were all tight up against the heads, but the bolts were loose. If you don't believe that the gov. can do things like that, you must have never been in the Army.
fasttruck
622
Mesa, AZ
Grease is cheap, parts cost money. Air is free and tires are not. most problems with loose hardware and u hoint failures on 809 series truc s seem to involve the shaft between the transmission and the transfer case.
EMD567
Driver for the Ga Mafia
44
Aiken SC
Whew, after 715 miles in mine, I guess I need to go out and check all the bolts in the drive line
myJEEPisAfatty
Chesapeak/Virginia
Good thing you werent going that fast, my friend had the same thing happen to his Suzuki Samurai and the shaft whipped around punching a hole in his transmission and cutting a huge hole in the floor. I think he was on the highway though. 0_0
crasheej
Hermitage,MO
You know when you have been a bad boy when you brake the slip shaft and the u joint at the same time. Been there done that snow was deep and the wind was out and must have been coming out of North Dakota. Those things are heavy and a lot of fun to put back in there when it is just you . Oh yes it is.
rchalmers3
30
Irmo, South Carolina
..... If you don't believe that the gov. can do things like that, you must have never been in the Army.
Amen brother, I was agape at the mixed/missing parts I found in the front axle of my first deuce.
A systematic rebuild of every component after purchase will be my method after this revelation.
Rick
