under rated data plates
WillWagner
2,610
Monrovia, Ca.
Did it feel like you had power steering with all the weight over the rear?
1,128
So when are you going to do a dump conversion?
It really helps for unloading :p
ken
25
Houston Texas
Yep the wife helped. I got i good one. I don't have to mow grass eather! We unloaded it in 2 1/2 hours with shovels. I work'ed out pretty well. You can put the truck where you need the sand and shovel it out. If i dumped it i would have to wheelbarrow it where i needed it. This is the first load with the drop side. It really made a difference. I didn't have to manuver the truck near as much. I still don't know i got along in life before i got this truck.
With this much weight steering is about as hard as before i put the lockouts on it. It carries the load pretty well. I got the sand for $13. To have a 9 yard dump truck bring it is $250. That makes the wife more tolarable of the truck.
jwaller
19
Columbia, SC
thats the same way my deuce paid for itself. I unloaded about 25 loads by hand nondropside in my backyard.
I love these things
ken
25
Houston Texas
I run 65 PSI in all 10 tires. They are 9.00's. I'm switching to 11.00's when these wear out. This is why i never switched to singles.
