Vacuum brake booster and master cylinder for modified m1028
alex33072
omaha, Nebraska
I got a vanilla m1028 a while back that had a bad motor. Removed the diesel engine and I'm putting in a 350 SBC. Has anybody had experience putting a vacuum booster and master cylinder in from a civilian comparable pickup truck? Am I going to have issues because of the larger brakes on the 1028? Anybody with experience in this area? Thank you.
Curtisje
654
Okinawa, Japan
I don't have any experience in swapping out a hydroboost system for a vacuum system.
Why do you want to make the change? Even the 1984 Chevy C30s with 350s had hydroboost.
alex33072
omaha, Nebraska
I guess the consensus is that I should keep the hydro boost. I thought that in the long run it would be cheaper and more reliable to put a vacuum booster in. Seems that many of you disagree. Thank you for your input.
Curtisje
654
Okinawa, Japan
I'm adverse to changing things that don't need to be changed but if you'd rather have a vacuum booster it's your truck and your decision. I just wanted to point out that the hydroboost is maybe more common than you know. And maybe you already knew that as well.
My 2000 Silverado even has hydroboost.
Good luck friend. I hope your project turns out the way you want it to.
alex33072
omaha, Nebraska
Thank you for your advice.
