Warn Jumper cables, Battery warmer and battery wraps done
WARWAG
Today I finished up making my own battery blankets and added two battery warmers undernieth. When I went to hook everything up I notice the loose negative on the front battery wasnt tightening up. It was loose when I took it off. Now I know why. It was broke. Never seen that before. So I installed a tinned battery terminal which I soldiered on the cable. From that point things went down hill as far as trying to get all my work done. The solder plug was to big for the only terminal end I had for that size cable. But i managed and should have everything hooked up tomorrow after I do my doghead realy mod. Heres the pics from todays work.
WARWAG
Tomorrow I will finish up the Doghead Relay mod and finish installing the PIAA lights. I need to add some spacers to get them leveled properly. If I have time I will finish installing the oil pan heaters and will hold off on the freeze plug heaters until I return. I ship out Saturday.
natemccabe
Fairbanks, AK
What is that plug for all your heaters and where did you find it? I'm looking at installing some battery warmers and maybe an oil pan heater and dont want the christmas tree light four way plug hanging off the front of the truck.
K9Vic
Fort Worth, TX
It is a quick release jumper cable hookup as seen commonly on tow trucks. Google "warn jumper cables".
