What are these?
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Maybe the brackets that hold the tube for shackles? I don't have a cucv so I don't know. I can only go by the marks on the bracket.
ida34
29
Dexter, MI
The are brackets that attach with the lift bracket mounts at the rear of the M1009. There is a rectangle tube that goes from one side to the other and the pintle hitch mounting plate attaches to the middle of the rectangle tube. The tube reinforces the bracket that the pintle mounts on since the bumper on the M1009 is so flimsy compared to a step bumper.
Does your truck have a receiver hitch installed? If so they probably took off the rectangular tube since it is in the way of the receiver hitch. This will also weaken your pintle hitch if you use it. My solution was to cut the tube down and mount it to the hitch side plate. Now I have the best of both worlds.
Goose2448
TEXAS Hanover, Pa/Bokeelia, Fl
I can tell you that one goes on the right and one on the left.;-) It looks to me like a shakle of some sort for mounting something on the frame.
I bet that you will find that these things dont even go on your truck, they were just thrown in there as a temp storage place and forgoten about.
Mudstone
Norman OK
thanks guys... i now looked at that page in the TM and i see the pieces... restoring my pintle has just gotten once step more difficult as i'm not missing one more piece. the bar that goes under these. :(
