- 6,610
- 9,211
- 113
- Papalote, TX
I have looked through all I have and don't see it,
Thanks but no, I am looking for the parts breakdown, all I have found was the 24 bolt even spaced which has the same valve stem as the 12 bolt, I know what the paired valve stem number is I was looking for the complete parts breakdown.
This correct for the paired wheel also...look at Item # 2....2 types of wheels...D and E range....paired is E range, so #3 is used for both.I found a copy of the 2009 revision of the ECV/REV parts manual. Only lists a single part number for the valve stem for both LR-D and LR-E wheels.
Looks like the difference between the valve stem is the 24 bolt wheels have the letter D at the end assuming you're talking about part #12 in the diagram below (90619 for the 12 bolt vs 90619D for the 24 bolt)
Yes, but it's also showing that there is only one valve stem assembly, and that isn't true because the E range have a different hole shape. If one thing is obviously wrong, then who knows what else is also wrong.This correct for the paired wheel also...look at Item # 2....2 types of wheels...D and E range....paired is E range, so #3 is used for both.
Ah, I see that now along with the #1, I miss copied the part number as 12518559 from my rim so my searches did not have any resultsThis correct for the paired wheel also...look at Item # 2....2 types of wheels...D and E range....paired is E range, so #3 is used for both.
