Wheel Bearring Grease
Loose Deuce
South MS.
Ok, I pulled my right rear wheels to change out a break wheel cylinder, which turned out to be ok. :shakehead: Didnt have that much grease on the bearrings, and the grease looks like regular multi purpose grease unless I'm wrong. Would it be better to use a good quality wheel bearring grease, the high heat type like you use on automobiles? :confused:
1,807
[3][green]I use GAA because it's cheap. A better quality grease can't do anything but good but there are tons of folks still using surplus GAA.[/green][/3]
