Where can I find one of these?
WillWagner
2,610
Monrovia, Ca.
I think that will be a hand made one off job. Looks good though! Looks off set at the bottom for tire clearance and that would help with the wt. distribution too.
AJMBLAZER
Paducah, KY
Guy over on www.ColoradoK5.com makes those. That particular one is some guy's own custom bumper with the tire stinger the guy on CK5 makes added to it. I believe he also makes entire bumpers with the stingers as well.
I like them but unfortunately my spare weighs 130lbs.
Croatan_Kid
New Bern, NC
I don't know where you can get one, but I can ask the guy that owns that Blazer. He's an Administrator on Carolina K5. Goes by the name of Dontoe.
tklm539
Bolton Landing NY
Thanks,
Sent some PM's. I would like to get on that could still use the original bumper if possible, and mount off the shackle holders.
Thanks for the info
Tom
AJMBLAZER
Paducah, KY
That's a good idea since you already have the pintle for a tow point.
Just make sure you can herc the weight of that stinger and a 35 back up in place. :wink:
rosco
Delta Junction, Alaska
That still looks pretty heavy, mounted that high up. Looks like it could be mounted lower on that same rack. That would give you some leverage in lifting it in place.
Lee on Alaska
AJMBLAZER
Paducah, KY
In order to get it lower you would have to make the tube kick out towards the rear lower and at a larger angle. That would cut into serious departure angle. DPI makes offroading oriented products.
