Where to buy bridge plate numbers?
Jinx
Buy me a Coke
130
Gainesville, Florida
My deuce came with a bridge place bracket, but no numbers. (See avatar) Can someone recommend a place to purchase a set of bridge plate numbers? From reading previous threads here, it looks like I need a set of 10 numbers. 5 on each side to keep them properly secured, or do I just need the 0 & 8 numbers?
Any suggestions? Is anyone parting out a deuce that still has the bridge numbers?
JDToumanian
14
Phelan, CA
Sounds like he needs the C plate, too....
If you can't find the pieces you need, the complete plate kits with the brackets and the mounts, bolts, etc. is usually around only $20 or so. Dave Walker / Walker Auto & Truck Wrecking has complete kits, he ships. 760-244-8060
Jon
Jinx
Buy me a Coke
130
Just wanted to say thanks to Maddawg308 for the bridge plate numbers. They look great! I've attached a couple of photos taken right after the numbers were installed. It was raining at the time so I got pretty wet. lol
Jinx
Buy me a Coke
130
My truck came without the radiator guard. The mount for the bridge plate came installed exactly as you see it. All I did was add the numbers. So I'm guessing it was used without the radiator guard.
How is the radiator guard mounted to your truck?
nchittendon
La Crosse, Wisconsin
Visiting old threads thanks to Google.......
I don't suppose someone could just MAKE their own plates? I have a M35A2 and I don't even plan on having a trailer (right now), so the "08" is all I would need anyways.......I already have templates for the numbers/letters, so would it be safe to assume I could just make my own? I already have the circle mount on the truck....
KsM715
142
St George Ks
You could make your own but the problem is that the top plate in combination with the rest of the numbers is what holds them all together so just one set of numbers wouldn't really do any good.
HDN
5,001
Finger Lakes Region, NY
Were these all metal or were plastic ones ever made? I could probably 3D print a plate out of ABS or ASA and make numbers for them, or get stick-on numbers from the local hardware store.
Otherwise I don't think it would make much a difference in material if someone was just looking at it instead of tapping it with a finger :p
juanprado
2,877
Metairie/La (N'awlins)
Rick Larson used to carry the number decals/stickers so you could refresh the numbers on old plates. Can't say I have see anyone making repro but yes, it would work just fine out of another material. They are relatively thin and typically hold 2 or 3 numbers per side.
  • Like
Reactions: HDN
