will a 1.5 kw 28VDC generator jump start an 003A
Scoobyshep
1,139
Florida
will the 1.5 KW 28VDC generator charge and jump the 002a 003a generators?
Never tried it. 1500 watts at 28 volt is 53 amps.
24 volt batteries, so the higher voltage helps. My gut says it wouldnt (amperage available is in the neighborhood of 500 amps). Maybe someone can prove me wrong.
Sent from my SM-G973U using Tapatalk
Coug
4,243
Olympia/WA
I'd say not likely. You're usually talking a couple hundred amps of power needed to crank an engine. Diesel engines need more than gasoline engines.
Even if it does have enough power, the throttle might not be able to respond to the instant demand for full load, and cause the engine to bog down (which increases the amount of amps that the starter is demanding to replace the loss in voltage)
Even if it's a couple of lawnmower size batteries, you really should have SOMETHING there to act as a reserve and buffer between the generator and the starter motor.
Worst case if you try for too long you burn up the 28v generator head, wiring in the gen, possibly catch it on fire (I said worst case) and burn up the starter motor. Best case you just bog down the 28v gen and kill it, not causing any actual harm to either piece of equipment. Reality usually lies somewhere in between. (do those 28V gens have breakers? might just trip them if it does)
I'd recommend against trying it, but that's just me, I tend to be more reserved in what I will do to my equipment.
Scoobyshep
1,139
Florida
Capacitor bank
Or has anyone seen a spring starter? (Some of the wild things found on youtube at 3am)
Guyfang
23,394
Burgkunstadt, Germany
Well, I have tried it. Several times. Short answer is, NO, if you just hook it up and try. What we did was hook it up, let it run a while, then the battery's will charge up, THEN try and start it. That works, most of the time. You all are forgeting that when the start switch is the start position, the heaters are also on. Its not just the starter draw. You could disconnect the heaters, and preheat the air going into the air filter housing. That works. Every unit had a battery charging panel. It was supposed to be hooked up to the 28 VDC 3KW gen set. THAT will also start the set alone. The 28 VDC, 1.5 was only used to charge battery's on trucks/jeeps/ tracks that were using the radios, and engine shut off. Oh, and we had 28 VDC light bulbs that we could use in our light sets. But the 1.5 was almost too small for that too.
1,807
I don't know what 1.5KW 28V set you are considering but if its the 2A016 gas powered one, they can be a pain to start in their own right. They have that wrap and hope pull start.
justacitizen
40
oklahoma
Thanks. is there a separate panel that goes between the 1.5 KW generator and the batteries to just charge the batteries? or i guess i am asking if there is some kind of charge controller or DCVR to protect the batteries?
Guyfang
23,394
No. You had two output lugs on the gen set. We used a trashed NATO jumper cable, that had one end gone. That was hooked to the output lugs. There were several other cables that were used to go direct to a radio setup. The charging panel was issued with a 3 KW gen set, 28 VDC out put. Later we simply ordered a NATO slave connector, and hooked it to the gen set, and attached the connector to a metal plate. That was screwed to the gen set frame.
