Windshield washer nozzle replacement
j_boucher
98
Virginia
Anyone have an easy way to get to the center windshield nozzle seems mine was broken off and I need to replace it
GeneralDisorder
4,904
Portland, OR
Maybe if you pull the gauge panel. Haven't looked at accessibility for that. Hopefully you can get to it. Otherwise it's going to be a lot of disassembly.
j_boucher
98
Virginia
I know I can see the broken piece in front but cant remove it because of the nut positioned to tighten it down . I wanted to at least just get the hose out where I could possible just put the hose through a rubber grommet .
j_boucher
98
Virginia
Thought I had the hose but it ripped and the other piece fell , so I will pull it apart and see hope fully I can get rid of that connection and just use the two outer,I need to plug it up first so it doesn't rain washer fluid in the instrument panel area lol
Ronmar
7,149
Port angeles wa
I am thinking that access is more like accessing the wiper linkage. Since it is in the front skin, It is forward of the dash, heater and power panel assemblies.
