- 272
- 468
- 63
- Las Cruces NM
I am wanting to install a battery kill switch that kills all power to my M923 to prevent low batteries or accidental fire from rodent damage. I plan on putting the switch on the negative side of the battery cable.
I also want to install a backup camera and rear spot lights. I am planning on installing a fuse box and a switch to each accessory and grounding these directly to the frame.
My question is if by cutting the main ground from the battery will the accessories still work? I really want the battery switch to cut all power to everything at once.
Turn the switch and everything is shut off. Please be gentle on advice and opinions. I’m an idiot when it comes to electrical stuff.
