dodjh
- 14
- 18
- Central, MS.
After cranking and idling, (which is no problem) if I press the gas pedal a little more the engine starts to die. If I hold it there it will die.
If I push more it catches and runs fine. The rpms just past idle, 700 - 800, is where it pulls down.
So if I remove my foot from the accelerator pedal and just let the jeep pull, it's fine. But if I start idling up a hill and need more fuel, when l press the accelerator just a little to make it up, it will start to die until I push the pedal and give it more fuel than is needed.
I have two inline filters, 1 before the fuel pump and one between fuel pump and carburetor. They both fill up with fuel.
What is causing this?
