Glider
- 227
- 43
- South Pittsburg, TN
No measurements. When I knock on the wood it makes a much deeper noise . I can hear new noises now![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f602.png)
.Installed 12v outlets.
I'm new to this, can I use a magnet to fish out, or do I have to make a home made pliers with a bend nose?Ummm.... you got more issues if that #4 plug left half of itself inside your engineInjector removal time and go fishing !!!
Isn’t dexron red ? Mine was when i put it in.I ordered a power steering filter from genuine hummer parts. 12.00 for filter and 18.00 for shipping. Whata a ripoff. Cheapest I could find the filter was 38.00 but I hate paying more for shipping than the part. I want to change my fluid because it doesn’t look bright pink anymore. I will probably Turkey baster out fluid in reservoir add new, run it, Turkey it out again until it’s clean and change filter. I don’t want to introduce air into the system if I can help it. Trying to find a Dextron 3 but everything thing has something else in it.
Hahaha. Probably so, I just seen a puddle of it on the driveway one time and it looked more pink and glowing kinda.Isn’t dexron red ? Mine was when i put it in.
Magnet is the trick. Pull injector and fish it out!!! Good luckI'm new to this, can I use a magnet to fish out, or do I have to make a home made pliers with a bend nose?
Did they come with the wire adapters?, if so I would say they intended for you to plug them into 24VThe ad said humvee H1. The voltage is listed at 12v. I could have sworn it said 24V....I guess that is my bad.
.Installed 100.00 LEDs from Amazon. They both popped after only a few seconds on. They also filled with moisture and there is some type of brown gel looking something on the inside of light. Theywent from Chrystal clear to badly clouded in a matter of seconds. Oddly enough the lights do work but the insie of lenses are ruined. I guess the brown stuuf was when from when something blew up in the light.
