Installing Antenna tip
CapePrep
194
MA
hey all, something so simple, yet escaping me. I did search, nothing specific. Is there a trick to installing a tip on antenna?? I have already cracked one a little bit doing what I thought was the way to do it. Slowly inserting the tip of fiberglass into the tip. Any help appreciated!
Guyfang
22,664
Burgkunstadt, Germany
If you look long enough, there are at least two P.S. Magazine articles on this subject. In the real world, we did just what Milcommoguy wrote. Also, if anyone has EM0079, There should be a TM in there that explains it ALL.
TOBASH
3,150
Brooklyn, NY
The method is similar to that used by King Minos of Crete. Not much has changed in 5000 years.
Milcommoguy
2,124
Rosamond, CA
Those pictured tips are for the skinny steel whips.
I have seen the plastic tear drop tips on fiberglass and steel all wrapped in tape to keep them on and last longer. I get they look cool, nice and shinny... till it gets sun baked or wracked to pieces. Best to have the right tip for the whip size too.
Military has tips, all others balls, CAMO
