texas-alex
- 12
- 3
- Texas
Howdy!
New owner of a gov planet USMC M1151A1 that runs and drives great, but has slow fuel drip when running. This is the first HMMWV I've ever owned, so I've been learning a lot as I go. I changed all the fluids (geared hubs, diffs, transfer case, trans, engine oil, coolant, and power steering) and have been adding the 'street legal-ing' pieces like windshields and license plate holders and such. It fires up first try every time, never studders or stalls, but I notice small drips of what appeared to be diesel dripping from below after the motor runs.
Troubleshooting lead to the engine valley drain, which in turn appears to be getting filled up by drips coming off of the Fuel Injection Pump.
Here is where the drip is forming (drip in center of frame, about to fall into engine valley), as viewed from the back passenger side of the engine valley. Worth noting is that there's a hose clamp sitting right under the Injection Pump, and I can't find a hose nearby that's missing one.
![vlcsnap-2022-12-03-20h59m04s924.png vlcsnap-2022-12-03-20h59m04s924.png](https://www.steelsoldiers.com/data/attachments/640/640779-1bba2bd5101ee59cae3275b955f70a99.jpg)
The passenger side of the Injection Pump looks like it may be corroded. I didn't see any drips from there, but possible the fuel is leaking out here and just running down to the bottom of the pump.
![vlcsnap-2022-12-03-20h59m43s570.png vlcsnap-2022-12-03-20h59m43s570.png](https://www.steelsoldiers.com/data/attachments/640/640780-bd5dc084b2a844cdee8efe62ed5541c1.jpg)
Has anyone seen this before?
Any things to check for before pulling the Injection Pump?
